Suggestions for a RS-485 repeater
xxtigerxx
Advanced Member level 1
Greece
I want to send a RS-485 more than 1200m so i what a RS-485 repeater.
Does anyone knows a circuit or a final product?
Thanks
:p
AdvaRes
At home
rs 485 repeater
Use max3192 IC.
xxtigerxx
Greece
RS-485 repeater.
there is not max3192 in maxim!!
AdvaRes
At home
Re: RS-485 repeater.
Sorry I mean 3291.
Please check this link:
Please push the helpedme button :D
FvM
Super Moderator
Staff member
Bochum, Germany
I see two points: MAX3291 isn't specified to extent RS485 at low baud rates above 1200m. It's specific preemphasis feature isn't effective for low baud rates respectively very long cables.
On the other hand, the specified RS485 1200 m limit is a convention without clear technical foundation. It's clear, that considerably higher distances are feasible at low baudrates.
AdvaRes
At home
Hi all,
Hi FvM.
Actually the premphasis il always better in terms of distances and baudrate according to the figure below:
FvM
Super Moderator
Staff member
Bochum, Germany
RS-485 repeater.
Yes, I've seen the diagram. If you look at the preemphasis timing, it involves a 100 ns current raise. So the effect is reduced below 5 Mbps and neglectible below 1 Mpbs, I think. The diagram was made by connecting two point with a straight line or drawing a parallel line through one point.
But if the diagram is meaningful at all, you could extrapolate the conventional driver line to 100 kbps and below.
AdvaRes
At home
Precisely, with a 1200 m you get a BW max of 3Mbps.
If this is not enough BW I'll use an ethernet connection if I was at your place xxtigerxx.
FvM
Super Moderator
Staff member
Bochum, Germany
RS-485 repeater.
The diagramm says 800 kbps for the MAX3291 and 400 kbps at 1200 m respectively 4000 ft. As I explained, the MAX3291 value is most likely an incorrect extrapolation.
AdvaRes
At home
You're right FvM. I didn't pay attention for the feet unity in the diagram.
Thanks for correcting !
Cheers,
Advares.
