v_suma
- Joined
- Mar 18, 2013
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,323
I am new to Digital Communications and MATLAB. I am learning to implement modulations and demodulations in MATLAB.
I have an amplitude modulated signal at the receiver input. I am trying to recover the message bits after the demodulation.
Following are the parameters of the modulated signal:
Carrier frequency = 22000 Hz (can be +/- 2000 Hz)
To decode the bits, the logic is that, if the width of the pulse is more then its 1 else 0.
I tried the following at the receiver:
1. Mixed the incoming signal with a locally generated 22000 Hz carrier.
2. Passed the signal through a Low Pass Filter with Fp = 2000Hz, Fs = 3000Hz
3. Obtained the envelope of the LPF output.
Can anyone please let me know if what I have done is correct?
Following are the waveforms at each stage:
Please suggest what steps to follow to decode the message bits.
Thanks,
Suma
Thanks,
Suma
