Suggest me simple projects in embedded systems
jitu_3022
Newbie level 3
plz can anybody suggests me a simple projects on embedded systems.
Re: embedded systems
What do you understand under embedded systems?
embedded systems with FPGA, Microcontrollers, PC/104,... ?
related to FPGA (RTOS)
Microcontrollers can be used from simple applications like temperature sensor to very complex things.
if u are referring to a graduation project, u can try these things:
1. Moving LCD/LED display using 8051
2. Intellegent car parking system.
the system provides user authentication using simple password mechanism. The entire system is developed around an 8051 Microcontroller, and coded in its assembly language.
and many more things u better sort it out on ur areas of interest.
You can build a stepper motor controller or a servo motor controller.
You can make a weather sensor like a rain meter or a temperature measurement system. Or make a small robot-like vehicle which can sense objects and take necessary decisions. The options are endless.. It all depends on what you want to do in the first place and your resources.
embedded systems
You can try making a simple one channel datalogger system..may be to measure rain/humidity for a purticular time
embedded systems
please suggest me a project and thesis topic for mtech in vlsi branch....
Added after 3 minutes:
in 60 days i want to complete my thesis work so please suggest me the topic on vlsi/ embedded branch.....
