Apr 29, 2019 #1 Z Zak28 Advanced Member level 2 Joined Aug 19, 2016 Messages 579 Helped 6 Reputation 12 Reaction score 6 Trophy points 18 Activity points 4,681 Whats the use for stud mounting 3.5W zeners such as a 1N1595A or a 5W stud mounted zener when there are very small 5w axial packages available? Can they at least clamp and handle much higher peak power than axial parts? Last edited: Apr 29, 2019
Apr 29, 2019 #2 Z Zak28 Advanced Member level 2 Joined Aug 19, 2016 Messages 579 Helped 6 Reputation 12 Reaction score 6 Trophy points 18 Activity points 4,681 Benefits aside from thermal impedance to heatsink.
Apr 29, 2019 #3 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,432 Helped 14,752 Reputation 29,786 Reaction score 14,106 Trophy points 1,393 Location Bochum, Germany Activity points 298,153 I'm not aware of in-production 3.5 or 5W stud mount zener diodes. They have usually 10W upwards. May there are some legacy types. Short time peak power depends on the die size, not the case.
Apr 29, 2019 #4 Z Zak28 Advanced Member level 2 Joined Aug 19, 2016 Messages 579 Helped 6 Reputation 12 Reaction score 6 Trophy points 18 Activity points 4,681 These do appear to be antiquated parts there are these https://www.ebay.com/itm/263722455074/ and a 3.5W stud mounted zener https://www.ebay.com/itm/223134043533 older semiconductors used to be made with quite large packages. Is continuous power dissipation rating indicative of a zeners die size?
