ants
Full Member level 4
I'm looking for some adhesive to glue a ceramic piezo to stainless steel. I've tried various superglues but the bond is quite weak. Can someone recommend a good type?
Thanks,
Ant.
Thanks,
Ant.
Any bonding material bond well only in case the surface is not moving. But in your case of ultrasonic cleaning aparatus, the Piezo will be working at a high frequency which will eventually loosen the bond between the two. The premanent solution is as described by "FvM" in his post above. CheersThank you both. The stainless steel is very shiny and polished, I will roughen it up and clean it and then use araldite.
Regards, Ant.
