Strip width of the fourth section of microstrip rat-race circuit
max232
Member level 5
The usual microstrip rat-race circuit constitus with tree adjacent sections are each lamda/4 , wile the fourth section is 3*lamda/4 .
How to find W (strip width ) of the four sections .?
Re: Rat-race Design
Check the link below. There is an on-line simulator too.
hxxp://www.ee.bilkent.edu.tr/~microwave/programs/magnetic/hybrid/hybrid.htm
(replace x with t)
rgds, Al
Re: Rat-race Design
If z0 is the impedence at the four ports, the ring has an impedence of sqrt(2)*z0
Re: Rat-race Design
Thank you has you, I know that the ring has an impedence of sqrt(2)*z0.
I sought the width of the stip , according to the site, the study of the width it is the same one as a line microstrip..
the site it is well especially the part java, one finds calculations sought. :D :D :D
Re: Rat-race Design
I need an 0-180 degrees hybrid component from 6 to 18 GHz..
It´s vrey important for me. Can anyone help me?
Thanks in advance.
Lupin
Re: Rat-race Design
I don't really think you can make it with hybrid coupler (branch line or rate race). I think you should use some wideband balun and make your circuit around it.
These are two papers to give you the hint
flyhigh
Rat-race Design
thanks flyhigh these papers are so good in UB Baluns.
are you have the paper of 100:1 Baluns? in this paper the author claim the 100:1 band width with coaxial balun!
Rat-race Design
thanks eng_ahmed214
these links are good!
Rat-race Design
SAJ25 Do u still have the link for the above? It seems broken.
Rat-race Design
Hi max232
The width will depend on Impedance.
Let us assume I have Rogers substrate, with Er =2.3 & h=31 mil
Usually, for Rat Race, The Input is 50 Ohm so width is 2.2mm
& width of ring will be almost equal to 1.8 mm (impedance 70 Ohm)
They are simple microstrip calculations.
Abhishekabs
Added after 2 minutes:
Hi Lupin
If you have ADS, use DG component(template) for Hybrid design.
It will be comparitively much easier.
Also Rate Race can be designed in ADS using template.
Added after 3 minutes:
Also check this
Rat-race Design
hi shinka
i used those links and they both are correct
Re: Rat-race Design
Hi all,
i am working at Rat-race coupler and i have a problem in calculation raduis of the ring in ADS design, i saw that it should be squre(2)Zo but i think it's not correct!!!
i attached the figure of design
Re: Rat-race Design
Hello people, I need to design a rat-race in C (5.03 GHz) band.
What technology do you suggest in terms of losses and weight? Stripline, WG or coaxial line?
Thanks for your support.
Lupin
