Aug 28, 2003 #1 S SadE Newbie level 4 Joined May 26, 2003 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 73 Hi , I'm testing Hitech C with this little sample program that normally toggle A0 & A1 ... But PORTA never blinks ... When I look at the asm code , the XOR is well generated !!! Coud you explain me why it doesn't work please ? #include <pic.h> #define XTAL_FREQ 20MHZ __CONFIG(WDTDIS & HS & PWRTDIS & BORDIS); main(void) { unsigned int i; PORTA=0x03; TRISA=0x00; for(; { for (i=0;i<1000;i++); PORTA^=0x03; } }
Aug 28, 2003 #2 T TheHungry Full Member level 2 Joined Mar 6, 2002 Messages 147 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,298 Activity points 999 main(void) { unsigned int i; PORTA=0x03; TRISA=0x00; while(1) { for (i=0;i<1000;i++); PORTA^=0x03; } }
Aug 28, 2003 #3 T TheHungry Full Member level 2 Joined Mar 6, 2002 Messages 147 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,298 Activity points 999 main(void) { unsigned int i; PORTA=0x03; TRISA=0x00; for(; { for (i=0;i<1000;i++); PORTA^=0x03; } }
Aug 28, 2003 #4 S SadE Newbie level 4 Joined May 26, 2003 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 73 after some investigation I found that the the same code work on PORTB and not on PORTA, even in asm !!! PORTA=0x00; TRISA=0x00; PORTB=0x00; TRISB=0x00; for(; { for (i=0;i<1000;i++); asm("MOVLW 01"); asm("XORWF 05,F"); asm("MOVLW 01"); asm("XORWF 06,F"); }
Aug 28, 2003 #5 picman2 Member level 2 Joined May 18, 2001 Messages 51 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 363 It seems you forgot to disable some analog features on your chip ! Read carefully the default state of I/O pins on datasheet, then initialize correctly them ! Cheers PicMan
Aug 28, 2003 #6 C C-Man Advanced Member level 4 Joined Jul 19, 2001 Messages 1,059 Helped 90 Reputation 180 Reaction score 17 Trophy points 1,318 Activity points 10,189 Which cpu are you useing? 16F877 and 16F627 / 628 switch PORTA to analogue mode on reset, you have to switch to digital mode if you want to use PORTA as output ... hope this helps
Aug 28, 2003 #7 S SadE Newbie level 4 Joined May 26, 2003 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 73 Yeahh you're right ! I have switched off the A/D but it seems you have to set the INTCON1 right . It's funny that only the XOR operator doen't work when portA pins are in analog mode. AND and OR are working ! thx
