ghattasak
Member level 1
Hello Guys,
i have the following sensor a general purpose strain gages from Vishay; EA-06-125BT-120/LE
but I do not understand how the sensor operates, does it outputs a specific voltage level dependent on the measured temperature ? or vibration?
and as for the output pins it is stated on the box "calculation of thermal output for strain gages" therefore does it matter which pin is the + or - and is it considered as a thermo couple ?
guide read: https://www.allaboutcircuits.com/textbook/direct-current/chpt-9/strain-gauges/
the formula placed on box is a polynomial expression: A0+A1*T^1+A2*T^2+A3*T^3+A4*T^4 where aN are the coefficients and T^N is the temperature, how are aN measured
In order to correctly aquire valid data from the sensors what will be my signal conditioning requirements and how is the output voltage read ?
"I have downloaded the pointed material TN-506 sensor document and the box contains a graph chart but no voltage output table, and as I read from previous posts the sensors need to be connected to bridges (half or full) not directly is it correct?"
Thank you in advance much appreciated
