Hi guys I am using 3 accelerometers ADXL335 in our project. Each accelerometer outputs data on X, Y, Z pins of the ADXL335 I will be using an ELB-REV4. How can I distinguish the data from each accelerometer?
Use different colors? Give them cute little names like “Beppo” and “Fluffy”?
Please, at least put as much effort into forming your question as the people on this board put into the answers. For starters, not everybody knows what an ELB-REV4 is. I just ASSUMED it’s some sort of Arduino or SBC...
You need assign suitable name for each accelerometer for example accelerometer1 pins 41, 51, 54 accelerometer2 pins 55, 56, 57 and the accelerometer3 pins 66, 67, 7 hence it is the coding that you can differentiate between 3 accelerometers by assigning suitable name for each accelerometer. any time you read value from pin 41 this means you are reading accelerometer1 X value and for pin 51 you are reading accelerometer1 Y value.
