Hi guys!
I'm rather new to ST microcontrollers. I have built a program using cube MX, and the generated code works.
Basically it's a program that takes the input from 8, 16 or 32 MEMS microphones as explained in ST's document
"Audio Processing With An Open Development System". The CPU is a F769, supposed to run at 216 MHz.
I set it to 196.608 which is a multiple of 48000 (audio).
All the peripherals (DMA, Timer, etc) work as expected. Now I have a problem with execution time.
Although the clock is pretty high (around 196 MHZ), copying a buffer with memcopy is incredibly slow.
I copy 3032 (or 6144) bytes, and it takes 830 µs, but with a clock at 196 MHz, I think I could expect it to happen faster.
Same problem if I copy the bytes in a loop.
So I thought that there might be something I'm missing.
Some background info:
I'm sure the clock works as expected. When dividing it by 64, I get a microphone clock of 3.072 MHz, confirmed
by the scope. So the core seems to run as expected.
Does anybody have some experience with STM 32? (Easyrider83 ??).
I also tried to run the program in run mode (i.e. not debug), but it doesn't change anything.
Thanks for any hint.
Dora.
Dora.
