STM32f4 board 5V pulse 40kHz frequency
victorrr
Hello, I modified the following program to get a 5V pulse at a frequency of 40kHz. I tried it in an oscilloscope and I get a 4 V pulse and 12,8 kHz of frequency. Can you help me?
#include "stm32f4xx.h"
#include "stm32f4xx_rcc.h"
#include "stm32f4xx_gpio.h"
#include "stm32f4xx_tim.h"
void TM_LEDS_Init(void) {
    GPIO_InitTypeDef GPIO_InitStruct;
    /* Clock for GPIOA */
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
    /* Alternating functions for pins */
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_TIM13);
    /* Set pins */
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
    GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
    GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_Init(GPIOA, &GPIO_InitStruct);
void TM_TIMER_Init(void) {
    TIM_TimeBaseInitTypeDef TIM_BaseStruct;
    /* Enable clock for TIM13 */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM13, ENABLE);
    Set timer prescaler
    Timer count frequency is set with
    timer_tick_frequency = Timer_default_frequency / (prescaller_set + 1)
    In our case, we want a max frequency for timer, so we set prescaller to 0
    And our timer will have tick frequency
    timer_tick_frequency = 84000000 / (0 + 1) = 84000000
    TIM_BaseStruct.TIM_Prescaler = 0;
    /* Count up */
    TIM_BaseStruct.TIM_CounterMode = TIM_CounterMode_Up;
    Set timer period when it have reset
    First you have to know max value for timer
    In our case it is 16bit = 65535
    To get your frequency for PWM, equation is simple
    PWM_frequency = timer_tick_frequency / (TIM_Period + 1)
    If you know your PWM frequency you want to have timer period set correct
    TIM_Period = timer_tick_frequency / PWM_frequency - 1
    In our case, for 40Khz PWM_frequency, set Period to
    TIM_Period = 84000000 / 40000 - 1 = 2099
    If you get TIM_Period larger than max timer value (in our case 65535),
    you have to choose larger prescaler and slow down timer tick frequency
    TIM_BaseStruct.TIM_Period = 2099; /* 10kHz PWM */
    TIM_BaseStruct.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_BaseStruct.TIM_RepetitionCounter = 0;
    /* Initialize TIM13 */
    TIM_TimeBaseInit(TIM13, &TIM_BaseStruct);
    /* Start count on TIM13 */
    TIM_Cmd(TIM13, ENABLE);
void TM_PWM_Init(void) {
    TIM_OCInitTypeDef TIM_OCStruct;
    /* Common settings */
    /* PWM mode 2 = Clear on compare match */
    /* PWM mode 1 = Set on compare match */
    TIM_OCStruct.TIM_OCMode = TIM_OCMode_PWM2;
    TIM_OCStruct.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCStruct.TIM_OCPolarity = TIM_OCPolarity_Low;
    To get proper duty cycle, you have simple equation
    pulse_length = ((TIM_Period + 1) * DutyCycle) / 100 - 1
    where DutyCycle is in percent, between 0 and 100%
    50% duty cycle:     pulse_length = ((2099 + 1) * 50) / 100 - 1 = 1049
    Remember: if pulse_length is larger than TIM_Period, you will have output HIGH all the time
    TIM_OCStruct.TIM_Pulse = 1049; /* 50% duty cycle */
    TIM_OC1Init(TIM13, &TIM_OCStruct);
    TIM_OC1PreloadConfig(TIM13, TIM_OCPreload_Enable);
int main(void) {
    /* Initialize system */
    SystemInit();
    /* Init leds */
    TM_LEDS_Init();
    /* Init timer */
    TM_TIMER_Init();
    /* Init PWM */
    TM_PWM_Init();
    while (1) {
well, without seeing the board, or even some data about it, I think the 4v could be a very common drop from a 5V USB+protection diode supply... (that if the waveform is square), also if you are driving some low impedance circuit (led? drive?) you can expect some voltage drop. (disconnect everything except the oscilloscope form the pin and check again) but aren this microcontroller in 3.3 or lower voltages?
for the frequency... it seems you code expect a system clock of 84MHz, sooo, how are you getting 84MHz? does it have a visible 84MHz crystal? dos it have another crystal value? do you need yo setup some internal PLL to get those 84MHz, try to post more information... meanwhile try changing the TIM_BaseStruct.TIM_Period value to something smaller, something like 672 and check the results...
