I would like to know whether it is possible to interface stm32f103vct6 with winstar display WF70Q using FSMC bus?
I would like to print moving images on the display.the datasheet for both are attached.
Also if it is possible to interface,which fsmc topology do we need to use?is it asynchronous non-multiplexed NOR write method?
What is the main difference between asynchronus multiplexed and non-multiplexed fsmc methods?
So if we are using the fsmc bus, is there any clock signal involved during communication?Since the display datasheet is talking about a system clock,so how should we give the clock needed for the display?
Also in the stm32f10xC datasheet,on page 68,there is a table showing the write timings.There what should be the minimum value of tHCLK when using the fsmc bus for disply?
