bonoko
Newbie level 2
- Joined
- Oct 30, 2011
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,349
Hello everybody,
I have a problem with STM32F3-Discovery and module HC-SR04.
My code:
My variable i_t isn't never i_t = 1! so program is never in the interruption.
Why?
USART result:
My code:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 #include "main.h" #define TIM_Period_init 40959 #define TRIGGER1_ON GPIO_SetBits(GPIOC,GPIO_Pin_0); #define TRIGGER1_OFF GPIO_ResetBits(GPIOC,GPIO_Pin_0); RCC_ClocksTypeDef RCC_Clocks; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; int ograniczenie_czasowe = 0; int i = 0; volatile uint16_t TIM_Period = TIM_Period_init; volatile uint16_t START_HCSR1 = 0; volatile uint16_t pomiar_HCSR1 = 0; volatile uint16_t pomiar_ULTRA_1 = 100; volatile int i_t = 0; char tab[10]; int main(void) { RCC_Configuration(); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); TIM2_Configuration(); GPIO_Configuration(); USART2_Configuration(); HCSR04_Configuration(); while (1) { ograniczenie_czasowe++; if (ograniczenie_czasowe > 5000000) { ograniczenie_czasowe = 0; TRIGGER1_ON; for(i=0;i<0x4;i++); TRIGGER1_OFF; START_HCSR1=1; sprintf(tab, "%d", i_t); send_string(tab); send_string(" END\r\n"); } } } void RCC_Configuration(void) { /* Before this function calling system is working on internal HSI 8MHz */ /* Flash 1 wait state */ FLASH_SetLatency(FLASH_Latency_1); /* HCLK = SYSCLK = 48MHz*/ RCC_HCLKConfig(RCC_SYSCLK_Div1); /* PCLK = HCLK = 48MHz*/ RCC_PCLK1Config(RCC_HCLK_Div1); /* Configure PLL ------------------------------------------------------*/ /* PLL1 configuration 8MHz/2 * 12 = 48MHz */ RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_PLLMul_12); /* Enable PLL1 */ RCC_PLLCmd (ENABLE); /* Wait till PLL1 is ready */ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { } /* Select PLL as system clock source (from HSI to HSI+PLL) */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /* Wait till PLL is used as system clock source */ while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08) { } } void send_string(const char *str) { while (*str) { while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); USART_SendData(USART1, *str++); } } void USART2_Configuration(void) { USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); USART_ITConfig (USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_7); // TX GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_7); // RX GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_Init(GPIOA, &GPIO_InitStructure); } void HCSR04_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; // PC1 -- ECHO 1 RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_Init(GPIOC, &GPIO_InitStructure); // PC1 EXT1 SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC, EXTI_PinSource1); /* Configure EXTI1 line */ EXTI_InitStructure.EXTI_Line = EXTI_Line1; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); /* Enable and set EXTI1 Interrupt */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); // Ustawienie wyjsc Triggering // Trig1 - PC0 RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_Init(GPIOC, &GPIO_InitStructure); } void TIM2_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; // 48 prescaleker #define TIM2_Prescaler 0x30 #define TIM2_Period 0x0001 /* TIM2 Periph clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); /* Time base configuration */ TIM_TimeBaseStructInit(&TIM_TimeBaseStructure); TIM_TimeBaseStructure.TIM_Period = TIM2_Period; TIM_TimeBaseStructure.TIM_Prescaler = TIM2_Prescaler; TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); TIM_ARRPreloadConfig(TIM2, ENABLE); /* TIM2 TRGO selection: trigger for DAC and ADC conversions */ TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update); TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE); /* Enable and set TIM2_Update Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); /* TIM2 enable counter */ TIM_Cmd(TIM2, ENABLE); } void EXTI0_IRQHandler(void) { if(EXTI_GetITStatus(EXTI_Line1) != RESET) { i_t = 1; if(START_HCSR1==2) { pomiar_ULTRA_1=pomiar_HCSR1/58; pomiar_HCSR1=0; START_HCSR1=0; } if(START_HCSR1==1) { pomiar_HCSR1=0; START_HCSR1=2; } EXTI_ClearITPendingBit(EXTI_Line1); } } void TIM2_IRQHandler(void) { pomiar_HCSR1++; TIM_ClearITPendingBit(TIM2, TIM_IT_Update); } /** * @} */
Why?
USART result:
0 END
0 END
0 END
