Jack.Straw
Member level 2
- Joined
- Apr 9, 2008
- Messages
- 47
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,792
Hi. I purchased a class-d dual channel audio amplifier on ebay. Specs are:
For my project there will be only one 4" speaker. Is it possible for me to combine the left and right channel into a single speaker? The seller says "it is not acceptable to connect the - outputs of the L & R speakers together."
Also, what kind of speaker should i use with this to achieve the best sound? It is intended for music playing via mp3 player / phone.
Thanks!
Features:
This board uses PAM8610 chip, PAM8610 chip is 10W (per channel) D-level stereo audio amplifier.
This board has over current / temperature / short circuit protection.
Specifications:
Work: D Class
Quiescent Current: 20mA
Efficiency: 90%
Rated output power: 10W+10W(8ω)
Frequency response: 20Hz to 50KHz
Operating voltage: DC7.5-15V
Recommended supply voltage: 12V, The center PIN of 12V DC is +.
PCB board size: (40 * 40*20) mm
100% Brand New
NOTE:
Thanks!
