wire stepper_i0; // your fpga internal signal that you want to go to the "I0" pin of the 3717
wire uc3717_i0_pado; // Output to the IOB pad.
// note the inversion to make up for the inversion done by the open collector scheme
assign uc3717_i0_pado = (stepper_i0 == 1'b1) ? (1'bz) : (1'b0);
Are you really sure you want to use P-fets? Doing the high side stuff yourself with discretes gets to be a hassle real fast. Especially if this is a hobby thing and the objective is to "save money". Because you won't save money by doing that.
Apart from that ... build a sin table (say 8 bits) for the reference voltage, use your favorite way to generate a voltage from this 8-bit value. I used pwm + RC lowpass for that and got about 7-bit accurate voltage, which was good enough. Then use comparators to compare the generated sin/cos with the voltage across your coil current sense resistors. Based on this comparator output you do your pwm for the coil drivers.
