hi,
I have 2 stepper motors to be controlled by dspic. I have programmed the pic. Im confused in usng L298 s. Can someone help me with a circuit diagram for stepper motor controller?
How can I implement micro stepping in it? what ic can I use for microstepping. If there is a circuit diagram with micro stepping, it will be of great help for me.
use the SLA70762M stepper motor translator IC from Sanken, its a single chip, more robust than the L297/L298 pairs, it also occupies less space.
You can also get 1/4, 1/8 and 1/16 step motion. The datasheet for the part contains a circuit diagram that describes the detailed operation of the device.
I have myself used the same circuit to make stepper motor controllers for my projects.
For a more advanced micro-stepping chip, try the Allegro series.
There are also many stepper motor controllers that can be easily configured using a mcu or a PC.
hi can a max233 can be supported an stepper motor?for example max233 can direct the rotation of the stepper?im dealing with the human motion tracking in matlab
hi,
