KhaledOsmani
Full Member level 6
Assume you have a stepper motor located at the center of a squarred room.
Assume you have 4 nodes located at the 4 corners of The squarred room.
Using PIC Basic Simulator IDE 18, with a PIC18f4520 controller, how to control the stepper motor (via StepCw & StepCcw) to make the stepper motor aims:
At each node of the squarred room with equal delay of 300 microseconds
To aim at the first two consecutive nodes of the room, with a delay twice than the other else nodes & vice-versa
To aim at two non consecutive nodes of the room with a delay triple than the other else nodes
The stepper mode value should be 1 or 2
In the basic help it is said that the first input for stepcw/stepccw syntax is the number of steps to be done, does that mean the real physical step
Finally and since there are 4 terminals for a stepper motor, how to connect it on proteus, true it is not labeled, hence the answer can be given as vertical parallel terminals first set and second set
Thanks
Thanks
