stepper motor code for cortex ARM help...
embed_v
Junior Member level 1
hiii i have some stepper code here but i am confusing the if (Motor_Steps--) statement so help me for understanding this code
BOOL Pulse_Motor(void)
if(State)
GPIO_PORTE_DATA_R = MOTOR_STEP_OUT;
State = 0;
else
GPIO_PORTE_DATA_R = 0;
State = 1;
Step_Table_Index++;
if (Motor_Steps--)
// Set next match value
TIMER0_MATCHR_R = TIMER0_TC_R+Motor_deltaTimer_Value;
else
Motor_Stop();
return 0;..................................is it right?
if any wrg then suggest plz...
You posted only a small portion of the code, but as far as I can see, this piece of code is related to pulse duration.
And, please, use CODE tags to format your code for readability.
	if(State)
		State = 0;
	else
		State = 1;
		Step_Table_Index++;
	if (Motor_Steps--)
	else
		Motor_Stop();
the if (Motor_Steps--) will be true as long as the Motor_Steps variable is not zero.
Note that a post-decrement operation (changed after evaluation) is used so the value will be evaluated and then decremented.
Code C - [expand]
++x;  --x;      // pre-increment/pre-decrement operation   (changed before evaluation)
x++;  x--;      // post-increment/post-decrement operation  (changed after evaluation)
Alex
hai,
can u send me whole code for stepper motor,I am doing a project regarding stepper motor control & also I want to create a GUI application to control it by using serial com, I have no idea about this, can u plz help me.
if(State)
State = 0;
else
State = 1;
Step_Table_Index++;
if (Motor_Steps--)
else
Motor_Stop();
LaTeX Commands Quick-Menu:
