Jun 20, 2014 #1 R raman00084 Full Member level 6 Joined Nov 29, 2010 Messages 362 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 4,006 i am using bipolar stepper motor it is possible to run the motor at 300 to 350 rpm using l297 / l298 drive. thank you
Jun 20, 2014 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,173 Helped 4,868 Reputation 9,757 Reaction score 5,540 Trophy points 1,393 Activity points 168,428 Hi, it depends on the motor parameters.. Klaus
Jun 20, 2014 #3 embpic Advanced Member level 3 Joined May 29, 2013 Messages 742 Helped 80 Reputation 160 Reaction score 77 Trophy points 1,308 Location india Activity points 5,213 if u r using 400 steps per revolution and keep step angle as 1.8 degree then u can get that much rpm.
Jun 22, 2014 #4 R raman00084 Full Member level 6 Joined Nov 29, 2010 Messages 362 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 4,006 how to keep 400 steps per revolution i cant understand, in 1.8 deg stepper motor per revolution it takes only 200 steps (360/1.8)=200 my stepper motor rating is 1.8deg , 200 steps per revolution, bipolar, 1.2nm Thanks & Regards,
Jun 22, 2014 #5 embpic Advanced Member level 3 Joined May 29, 2013 Messages 742 Helped 80 Reputation 160 Reaction score 77 Trophy points 1,308 Location india Activity points 5,213 Then its Ok and should rotate that much rpm
