STATIC void PPStartCode( byte xxx)
feiutm9898
Full Member level 4
Full Member level 4
Singapore
Hi.
During I study the source code which is C programing mixing assembly language.
I found:
Can anyone tell me what is the meaning of STATIC for embbeded C programming.
Thanks.
dipal_z
Full Member level 5
Full Member level 5
India
Functions with the static clause are local to the module/file. You can't call these functions from any other c file expect the one which defines it.
This helps us to prevent calling this function accidentally because if you do that compiler will give you a warning/error depending on implementation.
Check out this link for clear understanding with example
    feiutm9898
echo47
Advanced Member level 6
USA
That's true for static, but there's no such thing as STATIC in standard C.
It's probably defined in some special header file. Go search for it.
dipal_z
Full Member level 5
Full Member level 5
India
That's good catch echo47, thanks for correction.
    feiutm9898
feiutm9898
Full Member level 4
Full Member level 4
Singapore
If for a specific C compiler which not case sensitive, that mean STATIC is corresponding to static.
Correct me if I am wrong.
echo47
USA
All (non-broken) C compilers are case sensitive with keywords such as "static".
