State Machine with VHDL
matchit
Hi guys,
Below is a set of codes i have created. I need to change the codes in state machine format to transfer the code into my fpga board. i need some help here. thanks alot!
entity load_mode is
	port(clk1, reset, t, we, mode: in std_logic; --to controle the load----
			dins1,dins2: out std_logic_vector(11 downto 0));---to stock the coefficients---
end load_mode;
architecture Behavioral of load_mode is
signal i: integer range 0 to 31;
signal j: integer range 0 to 55;
type state_type is (s0,s1); -- type of state machine
signal current_s,next_s: state_type; --current and next state declaration
begin
	process(clk1, reset, mode)
		begin
			if (reset='1') then
				current_s <= s0; -- default state on reset
				dins1 <= "000000000000";
				dins2 <= "000000000000";
				i<=0;
				j<=0;
			elsif(rising_edge(clk1)) then
				current_s <= next_s;
				if (we='1') then
					if (mode='0') then ---mode0 => 80 MHz-----
						if (i <= 30) then
						dins1<=dins1_reg0(i);---load the coefficients one by one---
						dins2<=dins2_reg0(i);
						i<=i+1;
						else ---stop the incrementation of i----
						end if;
					else----mode1 => 32 MHz------
						if (j <= 54) then
						dins1<=dins1_reg1(j);
						dins2<=dins2_reg1(j);
						j<=j+1;
						else ---stop the incrementation of j----
						end if;
					end if;
				end if;
			end if;
		end process;
