Starting with AVR microcontrollers
What do you mean by GCC code, GCC is a compiler.
If it is a digital sensor then you can change manually the input state from the4 right side panel (the white/black boxes for ports) while using the software debugger of AVR studio but to debug a circuit properly you should use a hardware dev board.
how can we simulate the output of tsop1738 sensor.will its output be considered as PWM input.
