Standart VHDL function that rounds down numbers
shaiko
Advanced Member level 5
Hello,
Is there a standard VHDL function that accepts real numbers and rounds them down?
For example:
signal x : real
x <= 14.6 ;
A function that when applied on X will return 14.0
What's the functional deference between "floor" and "trunc"?
without looking at the actual package body the fucntion descriptions seems to indicate semantically different but identical behavior.
Reactions: shaiko
    shaiko
Presumably floor() and trunc() will give different results for negative numbers.
floor(-42.42) = -43
trunc(-42.42) = -42
Reactions: shaiko
    shaiko
Different result for negatives and same result for positives?
Yes. From the man pages:
floor(x)
... return the largest integral value that is not greater than x.
trunc(x)
... round x to the nearest integer not larger in absolute value.
Reactions: shaiko
    shaiko
