No detail of the feeding part can be seen on the picture. My best guess is that the left long trace works like a monopole, while the right short conductor serves as the ground. This guess is made due to the apparent asymmetric structure.
Based on the point where entry cable is supposed connected, seems more as a asymetric dipole type with a reflector, however such categorization I believe that properly doesn´t matter, due this geometry results from a irradiation pattern matching for several carriers, becoming a complex structure.
If you zoom in, we can see that the center conductor of the cable is connected to the structure above, but the bottom one to the outer braid of the cable.
It is a kind of asymmetric dipole with folded arms.
I think not even the designer of this antenna doesn't know exactly what it is. He just cut and paste in the simulator to get the best performances in specified bands.
The net, the antenna books, and the RF magazines, are full of examples of crazy shapes of printed antennas that takes a lot of time to understand what they are.
Of course, all of them have patent granted or pending.
Ok, it is an asymmetric dipole antenna. But then How it is possible to connect it to wireless modules with unbalanced inputs? Like here:
I thought that it is possible for monopole antennas. Or an antenna has a balun structure somewhere?
The problem is that the feed cable becomes part of the antenna, it's length and route influences the antenna impedance and directional characteristic.
To characterize the antenna on it's own, you can shove several ferrite tubes up the cable until the antenna entry point. On the other hand, the antenna will be rarely used without a transmitter board, so it makes possibly more sense to measure th eantenna characteric with the transmitter board in place.
