stability of pwm boost type dc-dc convertor
jcpu
Full Member level 4
hi,
need help to design /analyse open / closed loop
of pwm boost type dc-dc convertor.
best if we can have BODE plot
to fix those inductor, capacitor,... values
thanks in advance.
You can try with the book:
Switch-Mode Power Supply Spice Cookbook
Christophe P. Basso, McGraw-Hill
But you didn't mentioned if is boost voltage mode or current mode
please take a look at the many application notes found on the Texas Instruments web site. Look under the Training section and for the Unitrode power seminars.
fundamental of power electronics is also a good book to determine the small signal properties of power converters. The analysis in the book will be very helpful for designers.
The book has some dc-dc behavior Model example. You can use the model
to run the AC analysis with you compensation error amp.
:D
