shyam21
Newbie level 3
I have a LDO whose output acts as supply to a BGR and a secondary LDO. The output of the 2nd LDO acts as the reference voltage of the 1st LDO. I did stb analysis on both LDO's individually and both have around 60 deg phase margin. So i assume both are stable. Both LDO's work perfectly fine with a voltage source.
When the loop is formed, A start up circuit is used on the 1st LDO. When this start up circuit is on, the 1st LDO gets a Vref from another source and all 3 circuit work properly. When the start up circuit is turned off, the now stable 2nd LDO's output voltage is the reference voltage for the 1st LDO. During simulation, when the start up circuit is turned off, all the outputs starts oscillating at high freq. which looks like a loop stability problem. A stb analysis on the whole loop breaking the loop at the output of the 1st LDO resulted in gain less than 0 (so loop is always stable).
Any idea where the stability issues arrive from?
I tried another opamp (same LDO phase margin) but this time when the startup is turned off, all voltage goes to 0. I assumed that this is due to the slew rate of the opamp wasnt enough but even with better SR, the outputs was the same.
How can i proceed?
How can i proceed?
