alexdeus
Newbie level 5
Dear all,
I have a problem regarding the measure stability at 0 degree with ST L3G4200D gyroscope device.
The problem is that when I turn on my board in rest position, the 0 angle begins to increase; my board is contained in a case, so my doubt is that maybe the problem is just the increase of the temperature inside the case, because gyroscope datasheet reports a temperature drift of about 0.03 dps/°C. If it is so, how do you think I compensate this drift in temperature with an external circuitry?
Thank you very much in advance,
Al
Al
