spiral microstrip antenna with finite ground plane
chitra takle
Newbie level 3
hii,
i am working in HFSS v.10 and i am designing a spiral microstrip antenna with finite ground plane. However, i am getting most of the radiation below ground plane. Please help me detecting the problem with my design. i knw i can use finite ground plane but its impractical. i have to fabricate this antenna. so every dimension should be finite. no using sheets which has zero thickness coz again its impractical please help its urgent. thank you in advance.
Can you try playing around with your radiation box? The height should be minimun lambda/4. Not really sure if this will improve the results.
