Hi all,
I am using Momentum to synthesize the spiral inductor. I have created the substrate description file for Momentum usage. I have checked that the input parameter is correct. Then I use this to synthesize my simple spiral inductor. This is using the Top metal (M6) to make a spiral inductor path and M5 for bridge connection. The Via5 for M6 and M5 connection. After synthesiztion, I use the synthesized model and compared with the PDK inductor model. I want to see whether it close to the PDK inductor.
A special result is given out. During the Momentum synthesization, I have done 3 different Via5 simplification.
(Case 1): In the original layout, there are 7x7 Via5 for M5-M6 connection. I have done one of this model. (one Via5 is 4um x 4um, and Via5-Via5 seperation is 2um)
(Case 2): I have simplified the 7x7 Via5 and merge them in a one big square (the size of the big square is 40um x 40um).
(Case 3): I have simplified the 7x7 Via5 and merge them in a one little bit smaller big square (the size is 16um x 16um).
Then, I compared this synthesized inductors with the PDK inductor. A strange reuslt is given. The original PDK inductor give a Q=10 @10GHz.
Case 1 Ind: Q=12
Case 2 Ind: Q= 9
Case 3 Ind: Q= 8
How could I explain this result??
Thanks,
