I'm measuring an ac motor current via hall based sensor, at the same time via resistor to make a comparison. I filter the output of the sensor via low pass rc filter. I get good enough signal when rotor is locked and the waveform of the current is sinusoidal. But when motor rotates, sinusoidal form is get deformed and there are a lot of noise(spikes) on the waveform. What causes this noise and how can i eliminate it? Both resistor and hall effect based sensor gives the same respond about this noise.
Added after 34 minutes:
I investigate the signal via scope and saw that main spikes are at switching frequency. How can i prevent these switching effects not to affect measurements?
