spi related how many slave can communicate with master and distance betweem.
gajendra_808
Member level 1
ahmedabad/gujarat
hi to all.....
anybody how many slave can communicate with the master and how long the distance we can provide between master and slave....
hi to all.....
Hi Friend
you can use as many slave device as your master has Slave select Pin.
But communication possible between Master and any one slave at a one time.
For distance,
Keep sort distance between master and slave as possible(about 5 to 10 cm on one circuit board)
otherwise there is data lose problem.
Hope this is help you
Shyam
For distance,
the distance purely depends on the data rate and frequency of SPI.... and the cable used...
5 to 10cms is not a derived distance..
