SPI programming in Python - pyboard 1v1 + MPU9250
mheruian
Junior Member level 3
Hi Folks,
I am so beginner when it comes to embedded systems. I want to learn how to program them and a lot referred me to python since prototyping is fast and codes are simple to understand. I now know the basics of Python and I do like its straight-forwardness. I'm currently programming a Pyboard v1.1 and i now know the syntax on SPI also.
Now, i have my SPI device; it is a MPU9250 and I can't see python tutorial with it regarding SPI - all i2c. This leads me to reading internally the libraries of the SPI for MPU 9250 and done some coding like setting/writing modes then fetching raw/unprocessed gyro + accelerometer data and who_am_i of it. Now, when I'm going to test it out via interactive or script mode programming on python, i get data but all returns 0 or 0 > data. I do print the results and view them via python run by terminal/command line.
so far, i have tried (4) MPU9250 sensors and they always output 0x00 or 0 in whoami, (fifo count) sampling also of gyro and accelerometer is always 1. I have check my connections/wires and all are on their correct places:
MPU -> Pyboard:
SDA -> MOSI
ADO -> MISO
SCL -> SCK
nCS -> CS (GPIO)
Result of my simulation.
Then later on, the fifo count = 0 after few simulations
I don't have any oscilloscopes or logic analyzers as others suggest me to check it using those :(
I'll attach the code that I am using and THIS is reference (it's a github spi mpu9250 library, you can check its other files on that site also) I am decoding, what I'm after is the acquisition of initial raw data samples upon start up w/o processing them to real values and the who_am_i operation. The code is straight-forward where i didn't even create a separate file/library to handle spi transmission so you'll see a lot of redundant spi transmission codes.
I hope you can help me, Thanks :)
  • main.txt
