SPI: PIC18f4550 - MCP3201 ADC
asp87
Junior Member level 1
I'm trying to communicate with **broken link removed**(12 bit ADC) through SPI using PIC18f4550.
MCP3201 should start A to D conversion once the chip_select goes low. After 1.5 clocks, it'll finish sampling and send out the digital data MSB first.
My problem:
The code runs till the label "start_conversion" but not after that. I know this from the status of two LEDs, the commands for which are written before and after the start_conversion label. Can you please look into the code and tell where I'm going wrong?
In SPI protocol, when does the PIC start transmitting clock signal? Right after configuring or do we need to do something for it to start transmission? I measured the voltage at PIC RB1 pin (SCLK). It's 0V. Does it mean there is no clock signal?
 LIST P=18F4550        ;directive to define processor
     #include <P18F4550.INC>    ;processor specific variable definitions
     cblock 0x20
     d1
     d2
     d3
     RxData
     endc
     CONFIG    FOSC=HS                    ; HS oscillator, HS used by USB
     CONFIG    PWRT=ON                    ; Power on timer
     CONFIG    BOR=OFF                    ; Brown out off
     CONFIG    WDT=OFF                    ; Watch dog off
     CONFIG    PBADEN=OFF                ; Port B en digital IO
     CONFIG    LVP=OFF                    ; Pas de prog single supply
     CONFIG    ICPRT=OFF                ; Port de debug off
     CONFIG    DEBUG=OFF                ; Debug off
     org    0x00
     goto    main
     org    0x10
 main
     bcf INTCON, GIE
     movlw b'10000000' ; Fosc/64
     movwf SSPSTAT
     movlw 0x22 ; 0001 0110
     movwf SSPCON1
     movlw 0x00
     movwf    LATB
     movwf    LATC
     movwf    LATD
     movwf    TRISC ; RC7 is SDO
     movwf    TRISD
     movlw b'00000001'  ; RB0 is SDI, RB1 is SCLK
     movwf    TRISB
     bsf LATD,2 ; bring chip_select high
     call Delay
     bcf LATD,2 ; bring chip_select low to start A to D conversion
     bsf LATD,0 ; Green LED- This LED lights up
 start_conversion
     btfss SSPSTAT, 0
     bra start_conversion
     movf SSPBUF, 0
     movwf RxData
     bsf LATD,1 ; Red LED - This does not light up
     movlw 0x0A
     movwf EEADR
     movlw RxData
     movwf EEDATA
     bcf EECON1, EEPGD
     bcf EECON1, CFGS
     bsf EECON1, WREN
     bcf INTCON, GIE
     movlw 55h
     movwf EECON2
     movlw 0AAh
     movwf EECON2
     bsf EECON1, WR
     bcf EECON1, WREN
 loop_1
     nop
     bra loop_1
 Delay                 ;0.5 s, 20MHz
          movlw    0x01
          movwf    d1
          movlw    0x01
          movwf    d2
          movlw    0x02
          movwf    d3
 Delay_0
          decfsz    d1, f
          bra    $+4
          decfsz    d2, f
          bra    $+4
          decfsz    d3, f
          bra    Delay_0
          bra    $+2
          bra    $+2
          return
  end
start_conversion
btfss SSPSTAT, 0
movf SSPBUF, 0
movwf RxData
Since SPI read/writes at the same time and since your are a SPI master, I think you need to initiate a write so that the master will clock in the read data.
You might want to try writing to SSPBUF before your btfss instruction and modify your polling loop to branch back to the btfss instruction (not the write to SSPBUF which would now be at start_version)
I hope this helps, please let us know if it does.
Reactions: asp87
    asp87
I tried doing it for a while but didn't work. Hence proceeded with software SPI.
I'll try going the hardware route in a few days and let you know.
Thanks.
