Ravindrakant Jha
Junior Member level 2
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 #include <LPC213X.H> void delay(int msec) { T0MCR=0X04; //timer 0 match control register T0MR0=3000*msec; //Timer 0 Match Register T0TC=0X00; //Timer 0 timer counter T0TCR=0X01; //Timer 0 timer control register while(T0TC<T0MR0); } void SPI_init() //initialization function { PINSEL0|=1<<8; //SCK0 for SPI0 p0.5 PINSEL0&=~(1<<9); PINSEL0|=1<<10; //MISO p0.5 Master i/p slave o/p PINSEL0&=~(1<<11); PINSEL0|=1<<12; //MOSI P0.6 Master o/p slave i/p PINSEL0&=~(1<<13); S0SPCCR = 64; S0SPCR|=(1<<2)|(1<<3)|(1<<4)|(1<<5);//spi enable using microcontroller as master //spi sends and receive 8 bits of data //CPHA //CPOL } void SPI_tx(char data) //SPI transmit function { S0SPDR=data;//SPI data register while(!(S0SPSR&(0X80))); //SPIF low } char SPI_rx () //receive function { while(!(S0SPSR&(0X80)));//SPI data receive return(S0SPDR); } void SPI_string(char *str) { while(*str!='\0') SPI_tx(*str); } int main() { IO0DIR |= (1<<7); //Port 0 direction register SPI_init(); // SPI initialization IO0CLR |= (1<<7); // slave select pin initially low SPI_string("Hello"); while(1) { SPI_rx(); delay(1); } //IO0SET |= (1<<7); }
In the above code data is received continuously with a constant value 48 in the SPI Debugger.
I just want to know where my code is lagging.
