spi interface with eeprom
krish121
hi! i am interafcing eeprom with spi pic 18f . i am using following setting but my code doesn’t work.. i m using 25AA040 eeprom ..
SSPSTAT =0×40; // SPI MASTER MODE, spi clock select bit CKE=1
SSPCON1=0X30; // ckp=1
then spi write command
unsigned char spi_write(char c)
SSPBUF=c;
while(!SSPSTATbits.BF);
return SSPBUF;
i follow sequence in datasheet of 25aa040 to write data but when i read data it always zero result please help me.
to write data
CS = 0;
command for write enable
cs=1;
cs=0;
command for write instruction
command for lower address
send data
command for write disable
cs=1;
to read data
cs= 0;
command for read instruction
command for lower addreaa
data=SSPBUF; // read data
cs=1;
read data is at same location where i write data…. please help me..
hi! i am using with mode 0 ckp & cke are 0 but still when i read at eeprom i always get result 0.so please help me ... guide me.....
Wrong once more. ckp = 0 and cke = 0 sets mode 1 with PIC SPI interface. Please refer to the waveform in the datasheet.
By setting CKP = 0, CKE = 1, you get mode 0.
