I am trying to make SPI communication EEPROM X25128P(25C128 in Proteus) with atmega8. But i failed to do that.I can not understand where i have made mistake.I am using mikroC compiler.My code is given following...
Code C - [expand ] 1
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
sbit Chip_Select at PORTB0_bit;
sbit Chip_Select_Direction at DDB0_bit;
unsigned int buffer= 0 , value= 0 ;
void Init( )
DDRD= 0xFF ;
PORTD= value;
Chip_Select = 1 ; // Deselect DAC
Chip_Select_Direction = 1 ; // Set CS# pin as Output
//SPI1_Init(); // Initialize SPI1 module
SPI1_Init_Advanced( _SPI_MASTER, _SPI_FCY_DIV64, _SPI_CLK_LO_LEADING) ;
Delay_ms( 2000 ) ;
void spi( )
chip_Select= 0 ; //write latch enable
SPI1_write( 0x06 ) ; //enable write enable latch
chip_Select= 1 ;
Delay_ms( 10 ) ;
//write status register
chip_Select= 0 ;
SPI1_write( 0x01 ) ; //instruction to write in the status register
SPI1_write( 0x02 ) ;
chip_Select= 1 ;
Delay_ms( 10 ) ;
chip_Select= 0 ; //start of write operation
SPI1_Write( 0x02 ) ; //instruction code to write in the EEPROM
SPI1_Write( 0xC001 ) ;
SPI1_write( 0x04 ) ;
chip_Select= 1 ;
Delay_ms( 10 ) ;
chip_Select= 0 ; //start of read operation
SPI1_Write( 0x03 ) ; //instruction code to read in the EEPROM
SPI1_write( 0xC001 ) ;
value= SPI1_Read( buffer) ;
chip_Select= 1 ;
PORTD= value;
void main( )
Init( ) ;
while ( 1 )
Delay_ms( 1000 ) ;
spi( ) ;
corrected code of another compiler(like avrstudio then ok).Suggest me.
