SPI Communication between two PIC microcontroller
vinothksr08
Member level 3
Member level 3
Tamilnadu, India
dear friends i have completed the program for SPI communication between two PIC IC's... but i didn't get output... i have attached my coding with Proteus design please help me to complete my code.
  • Slave.txt
  • Master.txt
Hello there,
Actually what is your project.? Are using master-master communication or master slave communication?
Best regards,
Hello there,
Best regards,
sorry... actually am trying to do simple master to slave communication
am giving input in master and going to get that in slave....
thank u...
Hello there,
That is great. I hope master communication is fine in your code .but in your slave pic section you should use some receiver (spi ) interrupt.
Try these links and update me.
http://www.microchip.com/forums/m649226.aspx
http://www.microchip.com/forums/m505515.aspx
http://microchippiclessons.blogspot.in/2009/06/spi-tutorial.html
http://www.microchip.com/forums/m465519.aspx
http://www.ermicro.com/blog/?p=1846
http://embeddedcodesource.com/developer/microchip_technology_59/spi_slave
Best regards,
please check out this thread
https://www.edaboard.com/threads/293751/
hai
now am confused.!!!! i dont know what type of interrupt have to used in receiver side. and also i have to clear that my circuit is correct or not....
You can do like this. Use INT0 pin of slave to detect external interrupt. Let RD0 send a 1 to INT0 of slave. After slave detects 1 at INT0 then it will start sending or receiving data to/from master. implement SPI send or read code of slave inside ISR.
Hi there,
I attach for you SPI working example, one master and three slave mcu...
regards
  • SPI working example.rar
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
#include <p18f452.h>
void SSP_ISR();
#pragma interrupt chk_isr
void chk_isr()
    if(PIR1bits.SSPIF==1)
       SSP_ISR();
#pragma code MY_HiPrio_Int=0x08
void MY_HiPrio_Int()
    _asm
     GOTO chk_isr
     _endasm
#pragma code
void main()
unsigned char input;
SSPSTAT =0x40;
SSPCON1=0x25;
IPR1bits.SSPIP=1;
PIE1bits.SSPIE=1;
TRISCbits.RC3=0;
TRISCbits.RC4=1;
TRISCbits.RC5=0;
PORTC=0;
TRISB=0;
PORTB=0x0f;
TRISAbits.RA5=1;
void SSP_ISR()
while(SSPSTATbits.BF);
PORTB=SSPBUF;
SSPSTATbits.BF=0;
Its my new receiver code.... till i have same problem..., i have searched for many example codes.. but all of them using the inbuilt SPI functions... but i want to do it using C18 Compiler without MicroC Functions.
Hello there,
Instead of spi receiver interrupt you could use external interrupt module .So external interrupt would monitor the chip select pin from master and you could get data in external interrupt service routine .
Try and Update me.
Best regards,
