[AVR] SPI code generating weird behaviour
samir82show
Newbie level 5
Newbie level 5
Hi, I'm Samir
I finished coding SPI control of three servo motors, two of them are connected to the first micro, the third is connected to the second micro.
My problem is there is specific variable unsigned char state = 0; has to be exist and initialized otherwise the Slave code doesn't run.
attached the proteus image of connectivity and the code below
Master Code http://pastebin.com/EHSsMsnr
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
This program was produced by the
CodeWizardAVR V2.05.0 Professional
Automatic Program Generator
© Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l.
[url]http://www.hpinfotech.com[/url]
Project :
Version :
Date    : 1/20/2014
Author  : NeVaDa
Company :
Comments:
Chip type               : ATmega32
Program type            : Application
AVR Core Clock frequency: 1.000000 MHz
Memory model            : Small
External RAM size       : 0
Data Stack size         : 512
#include <mega32.h>
// SPI functions
#include <spi.h>
#define MAXANGLE 1999
#define MINANGLE 999
#define MOTOR_PLUS  0x08
#define MOTOR_MINUS 0x04
unsigned int Press_Conf = 0;
void main(void)
    // Declare your local variables here
    // Input/Output Ports initialization
    // Port A initialization
    // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
    PORTA=0x00;
    DDRA=0x00;
    // Port B initialization
    // Func7=Out Func6=In Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
    // State7=0 State6=T State5=0 State4=0 State3=T State2=T State1=T State0=T
    PORTB=0x00;
    DDRB=0xB0;
    // Port C initialization
    PORTC=0xFE;
    DDRC=0x01;
    // Port D initialization
    // Func7=In Func6=In Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=T State5=0 State4=0 State3=T State2=T State1=T State0=T
    PORTD=0x00;
    DDRD=0x30;
    // Timer/Counter 0 initialization
    // Clock source: System Clock
    // Clock value: Timer 0 Stopped
    // Mode: Normal top=0xFF
    // OC0 output: Disconnected
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    // Timer/Counter 1 initialization
    // Clock value: Timer1 Stopped
    // Mode: Fast PWM top=ICR1
    // OC1A output: Non-Inv.
    // OC1B output: Non-Inv.
    // Noise Canceler: Off
    // Input Capture on Falling Edge
    // Timer1 Overflow Interrupt: Off
    // Input Capture Interrupt: Off
    // Compare A Match Interrupt: Off
    // Compare B Match Interrupt: Off
    TCCR1A=0xA2;
    TCCR1B=0x19;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x4E;
    ICR1L=0x1F;
    OCR1AH=0x03;
    OCR1AL=0xE7;
    OCR1BH=0x03;
    OCR1BL=0xE7;
    // Timer/Counter 2 initialization
    // Clock value: Timer2 Stopped
    // OC2 output: Disconnected
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    // External Interrupt(s) initialization
    // INT0: Off
    // INT1: Off
    // INT2: Off
    MCUCR=0x00;
    MCUCSR=0x00;
    // Timer(s)/Counter(s) Interrupt(s) initialization
    TIMSK=0x00;
    // USART initialization
    // USART disabled
    UCSRB=0x00;
    // Analog Comparator initialization
    // Analog Comparator: Off
    // Analog Comparator Input Capture by Timer/Counter 1: Off
    ACSR=0x80;
    SFIOR=0x00;
    // ADC initialization
    // ADC disabled
    ADCSRA=0x00;
    // SPI initialization
    // SPI Type: Master
    // SPI Clock Rate: 250.000 kHz
    // SPI Clock Phase: Cycle Start
    // SPI Clock Polarity: Low
    // SPI Data Order: MSB First
    SPCR=0x50;
    SPSR=0x00;
    // TWI initialization
    // TWI disabled
    TWCR=0x00;
    while (1)
      // Place your code here
        if(PINC.7 == 0)
            Press_Conf++;
            if(Press_Conf >= 500)
                if(OCR1A < MAXANGLE)
                    OCR1A = OCR1A + 1;
                    PORTC ^= 1 << PINC0;
                Press_Conf = 0;
        else if(PINC.6 == 0)
            Press_Conf++;
                if(OCR1A > MINANGLE)
                    OCR1A = OCR1A - 1;
                Press_Conf = 0;
        else if(PINC.5 == 0)
            Press_Conf++;
                if(OCR1B < MAXANGLE)
                    OCR1B = OCR1B + 1;
                Press_Conf = 0;
        else if(PINC.4 == 0)
            Press_Conf++;
                if(OCR1B > MINANGLE)
                    OCR1B = OCR1B - 1;
                Press_Conf = 0;
        else if(PINC.3 == 0)
            Press_Conf++;
                spi(MOTOR_PLUS);
                Press_Conf = 0;
        else if(PINC.2 == 0)
            Press_Conf++;
                spi(MOTOR_MINUS);
                Press_Conf = 0;
Slave Code http://pastebin.com/3XvfCtkh
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
Project :
Version :
Date    : 1/20/2014
Author  : NeVaDa
Company :
Comments:
#include <mega32.h>
unsigned char data;
// SPI interrupt service routine
interrupt [SPI_STC] void spi_isr(void)
    data=SPDR;
// Declare your global variables here
void main(void)
    PORTA=0x00;
    DDRA=0x00;
    // Func7=In Func6=Out Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=0 State5=T State4=T State3=T State2=T State1=T State0=T
    PORTB=0x00;
    DDRB=0x40;
    PORTC=0x00;
    DDRC=0x00;
    PORTD=0x00;
    DDRD=0xB0;
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    TCCR1A=0xA2;
    TCCR1B=0x19;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x4E;
    ICR1L=0x1F;
    OCR1AH=0x03;
    OCR1AL=0xE7;
    OCR1BH=0x00;
    OCR1BL=0x00;
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    // INT0: Off
    // INT1: Off
    // INT2: Off
    MCUCR=0x00;
    MCUCSR=0x00;
    TIMSK=0x00;
    // USART disabled
    UCSRB=0x00;
    ACSR=0x80;
    SFIOR=0x00;
    // ADC disabled
    ADCSRA=0x00;
    // SPI Type: Slave
    SPCR=0xC0;
    SPSR=0x00;
    // Clear the SPI interrupt flag
    #asm
        in   r30,spsr
        in   r30,spdr
    #endasm
    // TWI disabled
    TWCR=0x00;
    // Global enable interrupts
    #asm("sei")
    while (1)
        if(data == MOTOR_PLUS)
                OCR1A = OCR1A + 1;
                PORTD ^= 1 << PIND7;
                data = 0x00;
        else if(data == MOTOR_MINUS)
                OCR1A = OCR1A - 1;
                data = 0x00;
thanks
Hey Samir....!
wher have you used that variable called state in both the programs...
I could just find "state" mentioned in comments alone
Hey Samir....!
exactly, the problem I'm not referencing or assign it to any value, I can even rename it to any other name, but it has to be existing and initiated.
You mean u can rename the variable state into someother????
Or do u mean u can change the name statex in those comments???
Since its a kinda auto generated code check in those function if there exits any variable with same name..!
I meant I have to have a variable and initiated, no matter the name was, putting unsigned char a; and the code will run perfectly.
Just try to simulate your code....! connect a spi debugger and check if u recieve desired values
Hi Ragul,
after debugging the SPI I found out whenever I add the above variable will cause the master to send the indicated value (multiplied by 2), thus sending 0x04 will be received 0x08 and 0x08 received 0x10 and the code runs perfectly, and whenever I remove the variable the transmitted value is correct, 0x04 will be received 0x04, and 0x08 will be received 0x08 but the code doesn't run and I can not control the motor further.
hey samir.. can u send me the routines for "spi.h"
il just check it up :)
sorry couldn't know how to attach spi.h and spi.lib below links for them
spi.h **broken link removed**
spi.lib **broken link removed**
