Since I am very new to microcontroller, can anyone please send example code on spi of pic18f45k20.??I am using MPLAB IDE and pickit debugger.
My actual task is as given below.
Here PIC should act as slave and the soon it receives command from other spi ( using chita adapter command will be sent) based on the command data (example : register value) should be sent through uart to pc.
