[PIC] SPI assembly code 18f4550
asp87
Junior Member level 1
I'm trying to interface 18f4550 with 25LC160A (serial ROM) using the PIC's hardware SPI module by polling method. It doesn't work. But it works when I implement SPI in software.
So here I am, trying to figure out how this thing works. Hence wrote codes for 18f4550 master---SPI--- 18f4550 slave communication. That doesn't work either. Below are the codes. Please point out the errors.
The Master will send 0x06 (b'0000 0110') to the slave forever.
The slave will check SSPSTAT, BF bit for '1'. If true, tests SSPBUF against the expected value 0x06. If true, turns ON an LED. Loops forever.
Master
[SIZE=1] LIST    P=18F4550
     include    "p18f4550.inc"
     errorlevel    -302,    -203,    -205,    -206
     CONFIG    FOSC=    HS
 cblock 0x000
 d1
 d2
 d3
 endc
 select_ROM    macro
     bcf PORTD,2
 endm
 deselect_ROM    macro
     bsf PORTD, 2
 endm
     org    0x000
     call    DelayHalfsec
     call    DelayHalfsec
     call    DelayHalfsec
     clrf    LATA
     clrf    LATB
     clrf    LATC
     clrf    LATD
     clrf    LATE
     movlw    0xFF
     movwf    ADCON1
     movlw    0x00
     movwf    TRISA
     movwf    TRISB
     movwf    TRISC   ; RC7 is SDO
     movwf    TRISE
     movlw    b'00000000' ;left pic master, RD2 chip select
     movwf    TRISD
     movlw    b'00000001'   ; RB0 is SDI, RB1 is SCK
     movwf    TRISB
     movlw    b'10000000';cke bit 6
     movwf    SSPSTAT
     movlw    b'00100010';ckp bit 4
     movwf    SSPCON1
 Send_DT
     movlw    b'00000110' ;data from Master to Slave
     call    SPI_Write
     call    DelayHalfsec
     bra        Send_DT        ; keep sending 0x06 to slave
 SPI_Write
     select_ROM    ; chip select is not used in this application
     movwf SSPBUF ;
 Char1 btfss SSPSTAT,BF
     bra Char1
     movf SSPBUF,W
     deselect_ROM
     return
 DelayHalfsec ; 20MHz
     movlw    0x15
     movwf    d1
     movlw    0x74
     movwf    d2
     movlw    0x06
     movwf    d3
 DelayHalfsec_0
     decfsz    d1,    f
     bra        $+4
     decfsz    d2,    f
     bra        $+4
     decfsz    d3,    f
     bra    DelayHalfsec_0
     bra        $+2
     bra        $+2
     return
    END[/SIZE]
Slave:
  LIST    P=18F4550
     CONFIG    FOSC=    HS
 cblock 0x000
 temp1
 d1
 d2
 d3
 endc
     org    0x000
     bra slave
 slave
     call    DelayHalfsec
     clrf    LATA
     clrf    LATB
     clrf    LATC
     clrf    LATD
     clrf    LATE
     movlw    0xFF
     movwf    ADCON1
     movlw    0x00
     movwf    TRISA
     movwf    TRISB
     movwf    TRISE
     movlw    b'00000100' ;right pic slave, RD2 chip select
     movwf    TRISD
     movwf    TRISB
     movlw    b'00000000';cke bit 6
     movwf    SSPSTAT
     movwf    SSPCON1
 Receive_DT
     btfss SSPSTAT, BF ; test BUFFER FULL bit
     bra Receive_DT   ; if not full, wait
     movff SSPBUF, temp1
     movlw b'00000110' ; this is the value expected from master
     xorwf temp1, w
     btfsc STATUS, Z
     bsf PORTD, 1  ; if expected data matches with actual data, turn ON LED
     bra Receive_DT  ; else, loop forever
     movlw    0x15
     movwf    d1
     movlw    0x74
     movwf    d2
     movlw    0x06
     movwf    d3
 DelayHalfsec_0
     decfsz    d1,    f
     bra        $+4
     decfsz    d2,    f
     bra        $+4
     decfsz    d3,    f
     bra    DelayHalfsec_0
     bra        $+2
     bra        $+2
     return
     END
Its always good to specify the important Config parameters to ensure they are always correct.
Even with SPI the chips internal oscillator is more than good enough.
These tutorials/ notes might help you solve your problem.
https://ww1.microchip.com/downloads/en/devicedoc/spi.pdf
;	Processor Type
	LIST P=18F4550,r=hex,n=80,x=off,st=off
	errorlevel -302		; no bank warnings
	#include <P18F4550.INC>
;	Configuration bits
; specified here are changes to the .inc file defaults
 CONFIG FOSC=INTOSCIO_EC,  WDT=OFF, PWRT=ON, BOR=OFF, MCLRE=OFF, LPT1OSC=OFF, XINST=OFF
 CONFIG LVP=OFF, VREGEN=OFF, PBADEN=OFF, DEBUG=OFF
Main		movlw	b'01000010'			; set internal osc to 4 mhz
			movwf	OSCCON
