speed control of toy train.
neiji
Newbie level 2
Newbie level 2
I would like to maintain the speed of 3-6V toy train. that is, the speed of a straight
path should be maintained along a circular path (the train has a slower speed in
circular track) and when the train is started in a circular path, it has the speed of the
straight path. the circuit I require more probably maintain the output voltage to be the
same in whatever situation.
A detailed explanation would be useful.
thanks
maby you can use better a current regulation.
Moustache
You may need to control the current flowing through a motor.
Simply you can check using a shunt register and comparator with driving transistors.
The voltage out from the series shunt registor will be compared with a reference voltage you set for the speed, and the comparator signal will control the driving transistors.
Once the speed is reduced at the corner, the current flow through the motor will also be decreased.
This will lower the voltage drop across the series shunt and will trigger the comparator to boost up the current into the motor.
Added after 19 minutes:
Check this out
Just simple reference.
Steve AHN
Added after 1 minutes:
since it takes more energy to make the turn, you will probably need to implement some feedback between the angle of the train wheels and your controller.
You may use feedback control to maintain the out put speed,( input parameter in voltage and current, out put parameter is speed).
