Speed control of DC motor/ Motor Control
chaudhary
Newbie level 6
pakistan
i want to control Motor speed.. i find some material on net & i try it on proteus but it didnt work.. i have attach full file with it can sum1 chek it & work it out.. it will be apreciate able
  • Motor control.rar
First of all re-design your proteus file as it has a pileup of errors compared to the original webpage. The project works fine. Relays used in your file are not animated too. You need to use animated ones to make the project work.
Cheers
can u tell me what kind of relays are used in this project.. can they b present in
Proteus?? if yesss then plzzz tell me... regards
In the device picking window, enter in the textbox "animated relay model". Select the required relay.
Hope this helps.
Tahmid.
NO Bro circuit iz still not working.. can u suggest similiar type of model of controlling DC Motor.. i think this circuit is not correct
