Mar 31, 2006 #1 S Syukri Full Member level 5 Joined Aug 9, 2005 Messages 249 Helped 24 Reputation 48 Reaction score 10 Trophy points 1,298 Location Malaysia Activity points 3,954 Spectre Problem... Hi alll..... I'm using Spectre on analogue Environment.....When the simulation is done, spectre window come out... The matters is that with default configuration...Y axis representing voltages and X for time... How do I chage the Y axis for Voltage Out and X Axis for input voltage...I want to find the ICMR value... by the way, maybe it's because I'm using transient analysis.. Can anybody help me.. Thanks in Advance
Mar 31, 2006 #2 Fom Advanced Member level 2 Joined Mar 10, 2004 Messages 630 Helped 84 Reputation 168 Reaction score 34 Trophy points 1,308 Location Taiwan Activity points 4,463 Re: Spectre Problem...
Apr 2, 2006 #3 L limingchou Member level 3 Joined Aug 24, 2005 Messages 57 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,711 Spectre Problem... dc sweep with input voltage.
Apr 2, 2006 #4 S steve_mac Junior Member level 2 Joined Nov 22, 2005 Messages 23 Helped 3 Reputation 6 Reaction score 0 Trophy points 1,281 Activity points 1,450 Re: Spectre Problem... Syukri, First of all you need to plot voltage out. then open another subwindow to plot voltage in . then at the first subwindow (voltage out) go to Axes-->X-axis--> and then change the plot vs value from independent to your value (voltage in)
