Specctra knows also Jumper autoroutes?
powerm
Member level 2
Member level 2
Specctra
8O
neuralc
Full Member level 4
Full Member level 4
Nop!
You must do it your self.
NeuralC
binu G
Advanced Member level 2
Bangalore
hi spectra is a strongest tool for a fast routing , but only the poor graphical interface, but very fast for routing, u can even program to route as per u r wish, through auto routing !
wilson
Member level 3
Member level 3
yes i think it can
hello
i think spectra supports jumper autoroutes....
for eg: a command in spectra for jumper vias look like this...
set jumper_via on
u can again search for jumper in spectra help...
hope will get what u want....
regards
Zenner
Full Member level 2
Full Member level 2
Try to use layout+, It supports jumper layer with several jumper types, automatic jumper placement, routing and conversion jmp to component. Very useful tool for single sided pcb's.
powerm
Member level 2
Member level 2
layout+ is good. Only Orc@d c@pture is shit. because of footprint. standard Parts have no Footprint entry. one must check always first with layout which footprnt is compatible. nervt animal. only p$pice parts has footprnt entry. :oops:
