spartan 2e audio output from gpio
cielobarnes
Newbie level 2
hi there,
i want to output monophonic tones generated by the fpga on my spartan 2e board through gpio.
how do i go about this?
is it alright to connect a piezo speaker (one wire to the pin itself and the other to ground) without damaging the board?
thanks a lot!
I think it will not work. Please connect a small transistor and then try.
Best wishes
Your project ok now ??????
I am doing Image compression implementing in FPGA. Are you have VHDL or Verilog code for this using any algorithm.
Sudan
