Good to see that you are once again looking AWR MWO...Was your Wilkinson Power Divider design went well!!!
I simulated couple of PIN Diode Switch circuits & found good results using AWR MWO ...
By the way which vedor PIN device your using is it M/A-COM or Microsemi? & is it Series or Shunt SP2T...?
If you have spice model for the PIN diode you can construct the Switch circuit within 2 minutes in AWR MWO ....
Also do you have the schematic diagram of the Switch ?
If not go through the free book on "THE PIN DIODE CIRCUIT DESIGNERS’
HANDBOOK" available online for download....
Hello Manjunath,
Yes,Power divider went quite well.Thanks for your help.
I am planning to use MACOM PIN diode switches in series-shunt combination(involving quarter wave transmission lines)
Please guide me regarding the usage of Spice models.
I am not having the Schematic but will post it tomorrow.
Can you share an example?
Thanks
Not easily done with that bandwidth. you will need a sp2t series shunt switch chip at the junction, and then additional shunt pins spaced at roughly quarter wave in the two arms.
