electronicsman
Full Member level 5
I am bit confused when you say the sources are in same direction or opposite direction. I assume that if the currents are in the same direction then they are is same direction for example i have drawn below. Is it correct?
Suppose if it is relatively complex circuit, still we can classify the sources in same direction or opposite direction? And in the case of AC sources if the sources are in opposite direction, does it mean they are phase shifted by 180 Degrees?
