when we have an external clock source and an PLL inside a chip level design from which point to which point will source latency be considered. As it is a chip level design consider the clock pad in between the external clock source and PLL.
if the clock is from,
External Clock Pin(Say IO pin) ----> PLL ----> Clock Generation Point
Source Latency is from PLL output to Clock Generation Point
For other cases like below
External Clock Pin -----> Clock Generation Point
Source Latency is from IO pin to Clock Reaching point/Generation point
This sounds more like you have two clock sources and they are either selectable, or they drive different clocks on the chip. If they are two different clocks then you need to specify both source latencies as stated by vikramc98406. If the clocks are selectable, then you need to create two SDC files and select one clock or the other and set the source latency as specified by vikramc98406.
