Gopikrissh
Newbie level 5
hello,
I have written a code for my project for the external interrupt in such a manner that when i trigger a particular pin high/low externally the lcd display should change but it is not working.Can you please tell me where have i gone wrong?
my code is as follows:
#include "LPC214x.H" // LPC2148 MPU Register
#include <stdio.h> // For Used Function printf
#include <lcd.h> //LCD INIT.,DATA & CMD
//#include "lcd_print.h" //WEL-COME SCREEN & MAIN MENU
//#include "baudrate.h" //FOR BAUDRATE SETTING
//#include "enroll.h" //ENROLL FUNCTION
//#include "diag.h" //DIAGNOSE FUNCTION
//#include "add_user.h"
//#include "identify.h"
//#include "deletealluser.h"
#define LCD_RS 0x00010000 // P1.16(0000 0000 0000 000x 0000 0000 0000 0000)
#define LCD_EN 0x00020000 // P1.17(0000 0000 0000 00x0 0000 0000 0000 0000)
#define LCD_D4 0x00040000 // P1.18(0000 0000 0000 0x00 0000 0000 0000 0000)
#define LCD_D5 0x00080000 // P1.19(0000 0000 0000 x000 0000 0000 0000 0000)
#define LCD_D6 0x00100000 // P1.20(0000 0000 000x 0000 0000 0000 0000 0000)
#define LCD_D7 0x00200000 // P1.21(0000 0000 00x0 0000 0000 0000 0000 0000)
#define ExtIntr 0x0000C000 //p0.7 as eint3
#define pin_0_7 0x00000080
#define LCD_DATA (LCD_D7|LCD_D6|LCD_D5|LCD_D4)
#define LCD_IOALL (LCD_D7|LCD_D6|LCD_D5|LCD_D4|LCD_RS|LCD_EN)
#define lcd_rs_set() IOSET1 = LCD_RS // RS = 1 (Select Instruction)
#define lcd_rs_clr() IOCLR1 = LCD_RS // RS = 0 (Select Data)
#define lcd_en_set() IOSET1 = LCD_EN // EN = 1 (Enable)
#define lcd_en_clr() IOCLR1 = LCD_EN // EN = 0 (Disable)
// xxxx xxx0 0000 0000 0000 0000 0000 0000
#define lcd_dir_write() IODIR1 |= 0x003F0000 // LCD Data Bus = Write
//#define lcd_dir_read() IODIR1 &= 0xFFC3FFFF // LCD Data Bus = Read
#define lcd_clear() lcd_write_control(0x01) // Clear Display
#define lcd_cursor_home() lcd_write_control(0x02) // Set Cursor = 0
#define lcd_display_on() lcd_write_control(0x0E) // LCD Display Enable
#define lcd_display_off() lcd_write_control(0x08) // LCD Display Disable
#define lcd_cursor_blink() lcd_write_control(0x0F) // Set Cursor = Blink
#define lcd_cursor_on() lcd_write_control(0x0E) // Enable LCD Cursor
#define lcd_cursor_off() lcd_write_control(0x0C) // Disable LCD Cursor
#define lcd_cursor_left() lcd_write_control(0x10) // Shift Left Cursor
#define lcd_cursor_right() lcd_write_control(0x14) // Shift Right Cursor
#define lcd_display_sleft() lcd_write_control(0x18) // Shift Left Display
#define lcd_display_sright() lcd_write_control(0x1C) // Shift Right Display
/* pototype section */
void lcd_init(void); // Initial LCD
void lcd_out_data4(unsigned char); // Strobe 4-Bit Data to LCD
void lcd_write_byte(unsigned char); // Write 1 Byte Data to LCD
void lcd_write_control(unsigned char); // Write Instruction
void lcd_write_ascii(unsigned char); // Write LCD Display(ASCII)
void goto_cursor(unsigned char); // Set Position Cursor LCD
void lcd_print(unsigned char*); // Print Display to LCD
//char busy_lcd(void); // Read Busy LCD Status
void enable_lcd(void); // Enable Pulse
void delay(unsigned long int); // Delay Function
/* Main Program Start Here */
int main (void)
lcd_init();
//IODIR1=~(1<<22);
while (1)
/* Loop forever */
//IOSET0=pin_0_7;
IO0DIR &=~IODIR0;
IO0DIR &=~(1<<7);
PINSEL0 &= ~PINSEL0; // Clear bits
PINSEL0 |= ExtIntr; // Set to EINT2 (11)
if(IO0SET==pin_0_7) /* P1.22 if set high */
lcd_write_control(0x01); // Clear Display (Clear Display,Set DD RAM Address=0)
goto_cursor(0x00); // Set Cursor Line-1
lcd_print(" INTERRUPTED ");
delay(100000);
else
delay(100000);
lcd_print(" WELCOME");
delay (100000); // Display LCD Line-1
if ((IOPIN0 & pin_0_7) == 1)
lcd_print("High");
else
lcd_print("Low");
/* Strobe 4-Bit Data to LCD */
void lcd_out_data4(unsigned char val)
IOCLR1 = (LCD_DATA); // Reset 4-Bit Pin Data
IOSET1 = (val<<18); // EN,0,RW,RS:DDDD:0000:0000:0000:0000:0000:0000
/* Write Data 1 Byte to LCD */
void lcd_write_byte(unsigned char val)
lcd_out_data4((val>>4)&0x0F); // Strobe 4-Bit High-Nibble to LCD
enable_lcd(); // Enable Pulse
lcd_out_data4(val&0x0F); // Strobe 4-Bit Low-Nibble to LCD
delay(100000);
//while(busy_lcd()); // Wait LCD Execute Complete
/* Write Instruction to LCD */
void lcd_write_control(unsigned char val)
lcd_rs_clr(); // RS = 0 = Instruction Select
lcd_write_byte(val); // Strobe Command Byte
/* Write Data(ASCII) to LCD */
void lcd_write_ascii(unsigned char c)
lcd_rs_set(); // RS = 1 = Data Select
lcd_write_byte(c); // Strobe 1 Byte to LCD
/* Initial 4-Bit LCD Interface */
void lcd_init()
unsigned int i; // LCD Initial Delay Count
PINSEL2 = 0x00000000; // GPIO1[31..26] = I/O Function
lcd_dir_write(); // LCD Data Bus = Write
for (i=0;i<1000;i++); // Power-On Delay (15 mS)
IOCLR1 = (LCD_IOALL); // Reset (RS,RW,EN,4-Bit Data) Pin
IOSET1 = (LCD_D5|LCD_D4); // DDDD:EN,RW,RS,0:0000:0000:0000:0000:0000:0000
for (i=0;i<100;i++); // Delay 4.1mS
for (i=0;i<100;i++); // delay 100uS
delay(10000);
IOSET1 = (LCD_D5); // DDDD:EN,RW,RS,0:0000:0000:0000:0000:0000:0000
delay(10000);
lcd_write_control(0x28); // Function Set (DL=0 4-Bit,N=1 2 Line,F=0 5X7)
lcd_write_control(0x0C); // Display on/off Control (Entry Display,Cursor off,Cursor not Blink)
lcd_write_control(0x06); // Entry Mode Set (I/D=1 Increment,S=0 Cursor Shift)
for (i=0;i<100000;i++); // Wait Command Ready
/* Set LCD Position Cursor */
void goto_cursor(unsigned char i)
i |= 0x80; // Set DD-RAM Address Command
lcd_write_control(i);
/* Print Display Data(ASCII) to LCD */
void lcd_print(unsigned char* str)
int i;
for (i=0;i<16 && str[i]!=0;i++) // 16 Character Print
lcd_write_ascii(str[i]); // Print Byte to LCD
/* Wait LCD Ready */
/*char busy_lcd(void)
unsigned long busy_status; // Busy Status Read
unsigned int i; // Delay Count
lcd_dir_read(); // LCD Data Bus = Read
lcd_rs_clr(); // Instruction Select
lcd_rw_set(); // Read Direction
lcd_en_set(); // Start Read Busy
for (i=0;i<1000;i++); // Delay Before Read
busy_status = (IOPIN1 & 0x80000000); // Read LCD Data(DDDD:EN,RW,RS,0:0000:0000:0000:0000:0000:0000)
if(busy_status == 0x80000000) // Read & Check Busy Flag
lcd_en_clr(); // Disable Read
lcd_rw_clr(); // Default = Write Direction
return 1; // LCD Busy Status
else
return 0; // LCD Ready Status
/* Enable Pulse to LCD */
void enable_lcd(void) // Enable Pulse
lcd_en_set(); // Enable ON
for (i=0;i<400000;i++);
lcd_en_clr(); // Enable OFF
/* Delay Time Function */
/* 1-4294967296 */
void delay(unsigned long int count1)
while(count1 > 0) {count1--;} // Loop Decrease Counter
/*void //tx0(unsigned char ch) //TRANSMITTING STRING TO USART0
char UDR0;
int tx_flag0;
UDR0=ch;
tx_flag0=0;
while(!tx_flag0);
tx_flag0=0;
