madmaiden
some basic questions
hello,
I have some basic question and reading different tutorials didn't help. I want to make a state machine that goes though all states a fixed numer of (let's say five) times then stops and waits until a button is pressed. I tried coding this in verilog and also in vhdl. no results. In order to test if the state machine was working i connected it to the tx pin, and every time it reached the first state a number was transmitted. It workes fine, but I want to make it transmit five values every time a button is pressed, no more no less. I have also a debounce block, that works fine.
I will post the code written in vhdl:
I tried different methods of checking the relation. None works, either it cycles though an infinite number of times, or none. I tried also sending nr to the PC, and the number I recieve are not consecutive.
How are additions performed?
How is a relational condition evaluated?
thank you,
Dinu.
hello,
fsm1: PROCESS (pb1,currentstate,tx_rdy,nr)
begin
case currentstate is
when idle =>
tx_write<='1';
if (tx_rdy='1') AND (nr<5) then
nextstate<=st1;
elsif (pb1='1')
nr="000";
else
nextstate<=idle;
end if;
when st1 =>
dat<="01010001"; --doens't really matter what it is transmiited for now
nr<=nr+'1';
nextstate<=st2;
when st2 =>
tx_write<='0';
nextstate<=st3;
when st3 =>
nextstate<=idle
end case;
end process;
thank you,
Dinu.
